ZS clutch hydraulic system "Upgrade" - Page 2 - XPowerForums - For MG, XPower & Motorsport Enthusiasts
Logo
Go Back   XPowerForums - For MG, XPower & Motorsport Enthusiasts > General Technical Section - ask the Experts! > Tyres / Wheels / Brakes / Suspension / Gearbox
Reply
Thread Tools
Old 06-06-2006, 22:36   #36
blue harbour
I miss you Dad!!!!!!
blue harbour's Avatar
blue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond reputeblue harbour has a reputation beyond repute
Default Re: ZS clutch hydraulic system "Upgrade"
Sheddist!
"You are a god amongst men!"- never let anyone tell you any different!!!!
Yes- ok, that's a shamless piece of line knickery from a film- but i satnd by it!
Just hope that you can mass produce the finished item for all us poor/unfortunate zs owning souls that will experience hydraulic failure's! dddc
__________________
The grass sometimes really is greener on the other side!
14.4 @ 102mph - nailing good 60ft's is a cow
Chrono Yellow FL LCR - turbo power is just so addictive!!!
blue harbour is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-06-2006, 22:52   #37
sheddist
A boffin and proud of it
sheddist's Avatar
sheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant futuresheddist has a brilliant future
Thanks chaps!
If I can prevent a problem at my leisure, then it is a pleasure! what really annoys is when I know that there will be a problem and cannot do anything about it.
If it all works OK, drawings will be posted. Also, if there is enough interest, I can arrange for steel parts to be laser cut and welded up. Price should not be too bad as all the parts will be flat.
let's not count chickens until they are hatched.
sheddist is offline   Reply With Quote
Old 06-06-2006, 23:03   #38
blue harbour
How ya going with your catch tank btw- since affecting my ickle tweak!??????
Mine's still fine n dry in the TB- how's your's!???
__________________
Old 06-06-2006, 23:15   #39
shroonie29
Audi S4 500HP
shroonie29's Avatar
shroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond reputeshroonie29 has a reputation beyond repute
On the question of catch tanks etc,what about a compromise,i'm thinking of fitting an inline breater filter(pipercross jobbie)could this not be kindof best of both worlds,i.e clean vapours/oil in plenum but still the lubrication that may or may not be needed??
Shroon
__________________
Audi S4 B8 3.0 V6 Supercharged
shroonie29 is offline   Reply With Quote
Old 09-06-2006, 23:21   #40
sheddist
sheddist's Avatar
Job done - almost
Well the Civic hydraulics are fitted plumbed, bled and working. Bracket works OK
[IMG][/IMG]
Used a 1.5m pipe from the master to the bracket that supports the battery tray, a flexible brake pipe off an escort about 250mm long then a 300mm copper pipe from the flex to the slave cylinder, brackets made to secure flex pipe using existing screws.
I did keep the existing cylinder location that meant a 36mm extension to the Civic cylinder was required. It may be possible to avoid this by mounting the cylinder closer to the lever. The pastic bush off the ZS cylinder can be used over the Civic push rod.
The Civic master cylinder is a bit different to the ZS
[IMG][/IMG]
The distance from the mounting flange to clevis is about 5mm shorter, resulting in a 30mm reduction in pedal height. There is, however, some free play in the push rod that means the pedal is still higher than it could be. next little job will be to take out this free play. When this is done, the clutch pedal will be almost the same height as the brake.
The Civic master does not have a fluid reservior. I could have used the Civic one but decided to make one instead. Much cheaper and quicker than trawling around the scrappies
[IMG][/IMG]
Result is that the clutch bite has moved a little closer to full pedal movement as expected, but feels more positive and lighter. Will measure the forces on Monday.
Old 10-06-2006, 07:07   #41
Byron
The mechanic
Byron's Avatar
Byron has a spectacular aura aboutByron has a spectacular aura about
Sheddist you are a god within the ZS forum .
That is a fine job you have done there so when you going to mass produce the kit's for us so no more failures dddc
Byron is offline   Reply With Quote
Old 10-06-2006, 09:44   #42
Gas-Axe
Gas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant future
Brilliant progress! The way it should have been done in the first place.
__________________
'06 330d M Sport Auto || Evolve Switch 300PS 500ft/lb || BMW Performance Brakes || Paddleshift Retrofit || Alpine HiFi Upgrade || 6CD retrofit || BMWP Gloss Grilles || oh and a Witter detachable hidden towbar LOL
Gas-Axe is offline   Reply With Quote
Old 10-06-2006, 09:53   #43
sheddist
sheddist's Avatar
Pedal travel now sorted. Made a stop
[IMG][/IMG]
that is attached using an existing hole in the pedal bracket.
[IMG][/IMG]
Good thing about the ZS, there always seems to ba a hole when you need one.
Pedal height is now as good as it gets, just a little higher than the brake. I could adjust the bite position and lower the pedal a little more by adjusting the pedal clevis and stop but that will do for now!
[IMG][/IMG]
Will see how things work out for the next week or 2.
Old 10-06-2006, 09:55   #44
Gas-Axe
Superb work & photos! Keep up the sterling work.
If I could award a forum OBE, you'd get one! :beer:
__________________
Old 10-06-2006, 18:44   #45
Trophy zs 180
Trophy zs 180 is on a distinguished road
I've just read this thread from start to finish. I am absolutely astounded! It's people like your good self who should have been on the development team. The knowledge and dedication you have is beyond words.
Keep up the good work and can't wait for this to be produced as I experienced this at 60k+ miles and what a TISH system it is. I can't believe they charge so much for the replacements.
As said before "KEEP UP THE GOOD WORK"
Rich
Trophy zs 180 is offline   Reply With Quote
Old 10-06-2006, 23:16   #46
DeMoNPauL
DeMoNPauL's Avatar
DeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond reputeDeMoNPauL has a reputation beyond repute
Quote:
Originally Posted by shroonie29
Amazing work and effort mate.It never ceases to amaze me the dedication you have
beer2 beer2
Shroon
Yeah long live sheddist
__________________
2005 Black Pearl MK2 MG ZS 180 V6 (Howlin Wolf)
Piper Stainless Steel Exhaust 100mm Slashcut Catback Growler
Janspeed 100 CPSI Stainless Steel Sports Cat
Janspeed 6-2-1 Stainless Steel Exhaust Manifold
ITG Maxogen Open Cone piped to inner wing
Team Dynamics Pro Race 1.2 Matt Neal Limited Edition Alloys
Vredestein Giugiaro Ultrac Tyres
Lowered 30mm on (Motobuild Koni) Springs
Stainless Steel Catch Tank
Sheddists Clutch Kit
NGK Iridium Spark Plugs
Philips X-treme Power Headlight bulbs
Customised Engine Cover
Tinted Windows
Rear parking sensors
Team Bobin Head
http://teamvalleylandrover.co.uk/ - MG Rover/Landrover XPART Auto Service Centre
http://www.hiperformanceautocentres.co.uk/ - MG Rover XPART Auto Service Centre
www.exv-mobile.co.uk - Mobile valeter in the Kent Area
DeMoNPauL is offline   Reply With Quote
Old 10-06-2006, 23:29   #47
shroonie29
Audi S4 500HP
shroonie29's Avatar
Looking good mate as Gas Axe said the way it should of been to start with.Looks like the probs could be a thing of the past
Shroon
__________________
Old 11-06-2006, 09:20   #48
blue harbour
Sheddist!- that looks absolutley brilliant mate!
You're deffinatley worth your weight in gold matey!
All we need now though, is for you to go out n rack up 50,000 miles of testing to see how well all the system works & how reliable it is! (but then again- seein as you're using honda parts- and thy're alloy and NOT plastic!- then they should last a LOT longer should'nt they!)
Can/will you be mass producing these kit's now for all us zed owner's who maybe wish to avoid hydraulic failures- or have suffered failures N need a worthwhile solution!?????????
How much has this all cost you to do anyhow (in terms of parts & materials?!?)
I'd be willing to volunteer as a 1st customer (if & when you start mass producing- maybe even fitting these kit's!)- granted i haven't suffered from any hydraulic failures YET- but it seems owners that DONT suffer failure's are VERY few & far between!
Good work anyway matey!- you should setup a business!
__________________
Old 13-06-2006, 12:19   #49
sheddist
sheddist's Avatar
Pedal forces : Original 31.5 lb, Honda hydarulics 26 lb with less travel. So the origianl system is that inefficient that it requires a higher force and longer travel to operate. The problam must be the plastic parts flexing under pressure.
I am gathering costs for all the parts required for an upgrade kit. When all is known then will advise. If I can get firm interest in say 20-30 sets, I may be able to get a better price for the cylinders.
Old 13-06-2006, 12:37   #50
Yugguy
Yugguy is on a distinguished road
I'm definitely interested.
Yugguy is offline   Reply With Quote
Old 13-06-2006, 15:36   #51
BanditSid
MG ZS 180 MGB GT V8
BanditSid's Avatar
BanditSid will become famous soon enough
I'm definitely interested too.
BanditSid is offline   Reply With Quote
Old 14-06-2006, 13:01   #52
Yugguy
What would be cool is if we could get a meet somewhere and all fit our new systems at the same time, that way we can help each other. It shouldn't be that complex, I've removed and refitted my existing master cylinder and pedal fitting and you don't need any special tools.
Old 14-06-2006, 15:07   #53
rphill
Registered User
rphill will become famous soon enough
I've lost confidence in my clutch since mine failed, which impacts on my enjoyment of driving the car, so add my name to the list (subject to finance but I'm sure I'll find it somewhere), although based on the fact that an X-Part slave cylinder is about 120 or so (can't remember exactly) then I guess we're looking at around the 300 pound mark for all this lot (stab in the dark estimate)? Is there a nice shiney aftermarket remote fluid cylinder about anywhere? If I was to do this upgrade I'd be looking to add new shiney things to my car. I remember one person offered chromed Rover power steering containers etc.
My respect for your endevours. That alu bracket looks great too!
rphill is offline   Reply With Quote
Old 14-06-2006, 18:04   #54
blue harbour
Well you can provisionally stick my name on the list of interested parties- subject to cost of required component's (abd my avaialable finances at the time!)
I know i have'nt had a hydraulic failure YET, but it seems almost everyone will suffer a failure at some point of atleast one part of the system!- so im thinking of this as a preventitive measure- aswell as an improvement!
One thing though- Does anyone have access to any of the honda forums?????- could do with digging around and finding out if any of the honda boy's suffer from clutch issues!!!!!!!!
__________________
Old 15-06-2006, 11:37   #55
rphill
Registered User
Quote:
Found it, these were the guys, although I've never bought anything from them.
http://www.roverdose.redmail.co.uk/detailing/detail.htm
Old 15-06-2006, 20:29   #56
Rapid Yellow
No longer a Rover / MG owner.
Rapid Yellow's Avatar
Rapid Yellow is a name known to allRapid Yellow is a name known to allRapid Yellow is a name known to allRapid Yellow is a name known to allRapid Yellow is a name known to allRapid Yellow is a name known to all
I'm definately interested, as I have had 2 failures of my clutch hydraulics already, and it is starting to feel not quite as good as when first fitted already
__________________
Currently driving boring sensible 1.4 Skoda Fabia
but project Turbo Skoda Rapid in process
Previously: modded Mk1 Trophy yellow ZS180
modded Rover 200vi (1.8 VVC ) - sold to be broken up for parts
Rapid Yellow is offline   Reply With Quote
Old 16-06-2006, 01:02   #57
dazultra2000
Registered User
dazultra2000's Avatar
dazultra2000 is on a distinguished road
Me too if it is my master cylinder that's up the duff...although car is in warranty..
out of interest, my car is suffering from "high pedal, quite a bit of free play" syndrome, but the clutch still works fine as it always has...
is it likely that the whole lots gonna go bang? or is this just an inconvenience?
How long does it take for a dealer to fix this using regular parts, as I need my car!
dazultra2000 is offline   Reply With Quote
Old 16-06-2006, 12:11   #58
sheddist
sheddist's Avatar
Takes less then 1 hour to replace the entire OE system with an OE system.
It loks like you are suffering from air entering the fluid. That may be due to the use of plastics that absorb water. I don't think your pedal is gettgin higher, rather the free play is due tot he fact you are compressing ari before movign fluid. Same happened on the Mrs. ZS120. Changed the slave for a spare I had "in stock" and all was well.
Old 16-06-2006, 23:21   #59
sheddist
sheddist's Avatar
For the upgrade kit comprising:
Aftermarket Civic master cylinder
Aftermarket Civic slave cylinder - with push rod bush*
Slave cylinder bracket*
1500mm copper pipe flared with fittings*
300mm copper pipe flared with fittings*
Flexible hose
Hose bracket*
Pipe P clip*
Fluid tank*
Fluid feed pipe with clips
Fluid tank mounting bolt and spacer*
Pedal stop with silencer*
Pedal stop fasteners
Instructions
Post and packaging
145
Parts marked * will be specially produced for the kit.
Any takers??
Old 17-06-2006, 07:29   #60
Byron
The mechanic
Byron's Avatar
That is a very good price indeed once fund's allow i will want one.
Old 17-06-2006, 07:54   #61
Bazza
Registered User
Bazza's Avatar
Bazza has a spectacular aura aboutBazza has a spectacular aura about
Amazing work sheddist mate. All credit to you.
__________________
Baz
Bazza is offline   Reply With Quote
Old 17-06-2006, 08:34   #62
Gas-Axe
Fantastic price, Sheddist. Well done.
__________________
Old 17-06-2006, 08:42   #63
dazultra2000
Registered User
My hand is up! I shall take if you shall giveth!
Old 17-06-2006, 11:36   #64
blue harbour
Hmm- will prob commit to this- when funds allow!
__________________
Old 17-06-2006, 16:33   #65
Trophy zs 180
I'm up for one of these kits soon. Got a few other things first but will have it when they are out of the way.
Exellent effort and keep up the good work
Rich
Old 17-06-2006, 21:26   #66
Parsec
Still not cured of MG addiction
Parsec's Avatar
Parsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond reputeParsec has a reputation beyond repute
Excellent stuff Nigel, the effort you've put in on this one has not gone un-noticed
__________________
MG-less at the moment
previously: MG ZS180 Mk2, MG ZR160, Rover 200vi
Don't forget the MG Rover archive :http://www.phoenix-mg-rover.org (use IE for best results as it's an old site)
My blog: http://www.blitterandtwisted.com - technology, gaming and entertainment
Parsec is offline   Reply With Quote
Old 17-06-2006, 21:38   #67
ZS
Double Agent
ZS's Avatar
ZS will become famous soon enoughZS will become famous soon enough
I want one please ... I assume there will be some sort of idiots guide to fitting for us mortals
__________________
You stupid idjit bedraggled dragon. I warned y'about lettin' yer fire git low. Nooooow you've caught cold
ZS is offline   Reply With Quote
Old 19-06-2006, 08:42   #68
Yugguy
Yep, I'm in.
Old 19-06-2006, 10:00   #69
Shantung Black Tiger
Registered User
Shantung Black Tiger's Avatar
Shantung Black Tiger has a spectacular aura aboutShantung Black Tiger has a spectacular aura aboutShantung Black Tiger has a spectacular aura about
I'd be interested in one please
Harbs, I'll have a dig through some Honda sites (see I knew there was a reason I owned a Honda Civic for a year ) and see if theres any clutch issues on any Hondas and report back :d
One thing I did notice in my Civic was that the clutch was actually very low and had very short range of movement. Once used to it, it was great for quick gear shifts.
__________________
Former ZS180 owner (x3)
Shantung Black Tiger is offline   Reply With Quote
Old 19-06-2006, 10:37   #70
Registered User
Quote:
Ref: me.... lol,
just spent an hour trailing through some honda forums. From what I can tell civic clutch hydraulics are pretty good. I found only two cases of possible master cylinder faliure and they were both on 120K+ mile cars. Most common civic clutch problems seem to be with release springs or mechanical faliure of the clutch itself. I believe the cylinder failures reported were of a result of corrosion due to water getting into the clutch fluid lines and rotting the inside of the cyliders, thus causing a leak and then a failure. So a bit of care on instilation and at fluid changes and I think the civic parts are pretty much bomb proof.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
