Oil Recommendations - Page 5 - XPowerForums - For MG, XPower & Motorsport Enthusiasts
Logo
Go Back   XPowerForums - For MG, XPower & Motorsport Enthusiasts > General Technical Section - ask the Experts! > Oil Recommendations - Fuel
Reply
Thread Tools
Old 02-03-2006, 14:22   #141
Mat-ZR120
Mat-ZR120 is on a distinguished road
Default Re: Oil Recommendations
Hi there oilman,
My first post on this site having been a member on mg-rover.org for a while though.
My question then, I have an 04 (MK1), 120 ZR. Its going in for its 2nd service tomorrow (25k). I want to change the gearbox oil but am unsure as to what it needs. I was under the impression that my car has a PG1 gearbox and MTF 94 is the oil of choice for it, is this correct? I tried an Ex Rover and Honda dealers but they dont stock the stuff. Are there any other gearbox oils i could consider.
Oh, car is used daily, it has a K&N panel filter and b/box.
Cheers in advance.
Mat-ZR120 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-03-2006, 15:08   #142
oilman
Registered User
oilman's Avatar
oilman is a jewel in the roughoilman is a jewel in the roughoilman is a jewel in the roughoilman is a jewel in the rough
Quote:
Originally Posted by Mat-ZR120
Hi there oilman,
Cheers in advance.
MTF stands for Manual Transmission Fluid and it is a very thin oil used in some boxes. Surprised the dealer doesn't have it.
I have two on my site Castrol SMX-S and Amsoil Synthetic MTF
Simon
__________________
Use the code XPOWER and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: [email protected]
phone: 01209 202944 Engine Oil
oilman is offline   Reply With Quote
Old 02-03-2006, 16:05   #143
Mat-ZR120
Thanks for that Simon.
What grade is the Castrol SMX-S? Left it till the last minute as usual so just trying to get hold of some for tomorrow.
Cheers.
Old 02-03-2006, 16:28   #144
Mat-ZR120
Actually cancel that Simon, just checked on your website, Doh!! Checked with my local Halfrauds and they have some.
Thanks for the help.
Old 02-03-2006, 22:18   #145
curious
curious is on a distinguished road
You might also want to check out Land Rover and Unipart MTFs.
curious is offline   Reply With Quote
Old 14-03-2006, 13:43   #146
nedd
nedd is on a distinguished road
Can you advise about Castrol TXT Softec Plus 5W-40? Is it fully synthetic or not, and is it suitable for K series 1.6 engine with about 70.000km?
nedd is offline   Reply With Quote
Old 14-03-2006, 14:27   #147
oilman
Registered User
oilman's Avatar
It is suitable (and it is labelled synthetic) but is in fact a hydrocracked petroleum oil.
Simon
__________________
Old 14-03-2006, 21:51   #148
roverman220
roverman220 is on a distinguished road
Hi Simon. Can you tell me any thing about " Chevron supreme synthetic, sae 5-40, apl/sl/cf , acea:A3/B3"? If it is any good would it be any good in a standard zs 180? Thanks, Tony.
roverman220 is offline   Reply With Quote
Old 16-03-2006, 23:10   #149
oilman
Registered User
oilman's Avatar
Very cheap if I recall correctly, at costco?
I know little about it other than the fact it's hydrocracked.
Stock road car, should be fine but there's a whole lot better out there.
Simon
__________________
Old 17-03-2006, 05:20   #150
roverman220
Thanks Simon
Old 19-03-2006, 11:45   #151
GazSuttonUK
MG XPower.
GazSuttonUK's Avatar
GazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to beholdGazSuttonUK is a splendid one to behold
Simon,
thanks for my recent order from yourself.
Our MG ZR 105 will be 12 months old in May. Only done 2,000 miles, would you recommend 'Mobil 1' on an engine this new?
Regards,
Gaz.
GazSuttonUK is offline   Reply With Quote
Old 19-03-2006, 13:07   #152
oilman
Registered User
oilman's Avatar
Daz,
Yes that should be fine, it only really takes about 1000 miles to run in, in if doubt though use a semi for another 1k.
Simon.
__________________
Old 19-03-2006, 14:58   #153
GazSuttonUK
MG XPower.
Quote:
Originally Posted by oilman
Daz,
Simon.
I've been called somethings but never Daz before!
Simon,
I'm not going to cause any damage am I?
What would you advise?
Regards,
Gaz
Old 19-03-2006, 20:04   #154
oilman
Registered User
oilman's Avatar
Quote:
Simon,
Regards,
Gaz
Sorry Gaz,
No you won't cause damage
Regards
Simon
__________________
Old 22-03-2006, 19:56   #155
AdT
Registered User
AdT is on a distinguished road
Hello there,
What is the best choice for my ZT diesel (131 bhp) 2005.
It has done 23.000km's and is used very often for short tracks so the engine stays cold most of the time.
My other car is an MG (of course) in fact MGB 1971. I'm now using 15w50 in it. The car is for long summertrips only.
And is 20w50 still a good choice for the gearbox in this classic?
Cheers (with some Old Speckled Hen if available here in Holland)
Ad
AdT is offline   Reply With Quote
Old 23-03-2006, 13:48   #156
Paul Wiley
Paul Wiley is on a distinguished road
Ad
Interesting research on box oil
http://www.quantumechanics.com/categ...index&catid=11
Apart from std 20W50 Millers have a classic mini version which should increase protection and Penrite have have some oils that look suitable re the above.
Synthetic (Royal Purple) may cause a problem with overdrive although the EP additives may be less corrosive in modern gear oils.
Paul Wiley is offline   Reply With Quote
Old 27-03-2006, 11:14   #157
Jerry ZS180*
Registered User
Jerry ZS180*'s Avatar
Jerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud ofJerry ZS180* has much to be proud of
Question Re: Oil Recommendations
Hi there,
Non-MG this one but I wonder if you can help..
My old man's 1993/L Jaguar XJ Sovereign 4.0 (3980cc 6cyl) needs a service and I would like to know what oil I need... Its the XJ40 range, it has 86000 miles on the clock and he only does about 3000 miles a year these days..
Any info would be a great help.
J
__________________
STILL Missing the XPG Beastie Does anyone know where YE52YFT is?
...Jerry went DERV with an Astra 1.9 CDTi SRi 150 XP with DTUK Eco3 'Green' box & K&N Filter which SUCKED!
Now got a 2004 Seat Leon Cupra R 225 in Silver Its nice & fast but is boring compared to the Zed
Jerry ZS180* is offline   Reply With Quote
Old 27-03-2006, 14:20   #158
nedd
Simon
Hi Simon, thanks for the reply. What is your suggestion for the next oil change - do I need to continue with Castrol TXT 5w-40 which is in engine now? What about "downgrading" to some 10w-40 semi-synthetic? When I bought the car before about 6 months it had about 60.000km and was filled with some "unknown" 10w-40 oil. Soon after I replaced it with Castrol TXT. Now I am not so sure is it a really right choice.
Old 30-03-2006, 16:33   #159
Aidan
Registered User
Aidan is on a distinguished road
Hi,
I'm storing a 1969 MG Midget, however have drained gearbox and engine oil and imagine would be better to stand it with oil in it - which should I get, not to run engine, just to sit there!
Non-MG question i'm afraid.
What oil would you recommend both for the gearbox of a 2-stroke 18,000 1982 yamaha RS200 motorbike and what two stoke oil should I use to mix with the fuel? Want one which is readily avaliable and not too expensive as just a commuter bike
Thanks,
Aidan
Aidan is offline   Reply With Quote
Old 31-03-2006, 07:15   #160
MarkB
ZS220 - It's All About the Cams...
MarkB's Avatar
MarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to all
Aidan - Im not expert on the subject, but if the engine is going to be standing a long time you may want to consider:
1. Putting Reddex down the bores (lube)
2. Turn the engine once a week (either on the key without the plugs in or if the engine is out do it manually by cranking it)
3. Squeezing the clutch and brakes - so they don't seeze up.
Bet you could get some advise from MG Owners or Car Club - give them a ring.
__________________
MarkB
MKII ZS220 Pilot
Voted Best Sports Saloon Gaydon 2006
183.9 BHP @ the Wheels (Measured)
221.6 BHP @ the Fly Wheel (Calculated)
Piper 270 High Lift Cams, Super Chips Custom re-Map
Janspeed Full Exhaust System & Open Filter Cone Custom set up
MarkB is offline   Reply With Quote
Old 31-03-2006, 07:16   #161
MarkB
MarkB's Avatar
Oh, one other thing. I think your right, better to have the oil in it rather than without - corrosion.
__________________
MarkB
MKII ZS220 Pilot
Old 05-04-2006, 20:36   #162
andylew0
Tick Tock Tick Tock
andylew0's Avatar
andylew0 is infamous around these partsandylew0 is infamous around these parts
zr 120 53 plate
andylew0 is offline   Reply With Quote
Old 05-04-2006, 20:44   #163
oilman
Registered User
oilman's Avatar
5w-40 full synthetic as the top option, the cost route is for a 10w-40 semi synthetic changed twice as often.
Simon.
__________________
Old 05-04-2006, 21:01   #164
andylew0
Tick Tock Tick Tock
andylew0's Avatar
do you mean change the 10 40 twice as often
Old 05-04-2006, 22:00   #165
oilman
Registered User
oilman's Avatar
Yes, a mineral based oil will only go abbout half the distance of a true synthetic.
Simon.
__________________
Old 06-04-2006, 08:18   #166
MarkB
MarkB's Avatar
Hi Oilman,
What offers the most protection - in terms of engine wear cold? and hot?
Magnatec 10/40 semi syth make a BIG thing of its cold start protection. Is a fully Syth as good or better for cold starts ? (75% of engine wear is cold starts apparently)
Im guessing that when hot, the full syth offers the better proection (esp. if racing) but this only represents 25% of wear - according to the TV advert.
Cheers Mark.
__________________
MarkB
MKII ZS220 Pilot
Old 08-04-2006, 20:23   #167
Paul Wiley
SAE Findings
a pair of Mercedes-Benz Engineers (Rudolf Thom and Karl Kollman)along with pair of Shell Oil engineers (Wolfgang Warnecke and Mike Frend)wrote an SAE technical paper (No. 951035) on "Extended Oil Drain Intervals: Conservation of Resources, or Reduction of Engine Life?" Among the many interesting results presented in the paper was a graph showing cylinder-wall wear-rate Measurements correlated with cylinder wall temperature. Cylinder wear rates(in micrograms per hour) were monitored as a function of cylinder-wall temperature in a test engine specifically fitted with radionuclide-impregnated cylinder liners. Three test were done so that three different kinds of oils could be used. In one test sequence, a straight 30 weight oil was used; in another, 10W-30 multigrade; and in the third, straight 10 weight oil. (The test engine was a Mercedes-Benz OM 616 2.4-liter, 4cylinder diesel.) In each case, the engine was operated at fixed speed, torque and temperature conditions until constant wear rates were observed. Wear rates were then plotted against cylinder wall temperature.
The graph of cylinder-wall wear rate versus cylinder wall temperature tends to be bathtub-shaped, with wear increasing sharply at each temperature extreme (as you'd expect). But while two of the oils turned in very similar wear performance, one oil stood out as protecting the engine against wear at the extremes of temperature. That oil was plain SAE 30 (Straight-grade 30-weight). At either extreme of temperature, the maximum wear rate with 10W-30 was more than double that of the straight SAE30 oil. (The worst performance was turned in by straight 10-weight.)
Ester based oils such as Redline are straight-grade
http://www.redlineoil.com/products_m...sp?subcatID=15
The "UMA" of Magnatec is an ester added to mineral oil.
Ester based synthetics should therefore provide better cold and hot wear
Old 09-04-2006, 07:37   #168
Gas-Axe
Gas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant future
Think I'd better have some radionuclide liners!
__________________
'06 330d M Sport Auto || Evolve Switch 300PS 500ft/lb || BMW Performance Brakes || Paddleshift Retrofit || Alpine HiFi Upgrade || 6CD retrofit || BMWP Gloss Grilles || oh and a Witter detachable hidden towbar LOL
Gas-Axe is offline   Reply With Quote
Old 09-04-2006, 21:13   #169
johndjlawson
Registered User
johndjlawson's Avatar
johndjlawson will become famous soon enoughjohndjlawson will become famous soon enough
hi simon, im going to order the silkolene pro s 5w40 for my zs180 which is not modified but how much will i need, you only seem to have 5 litre bottles and not 1 litre, dont really want to buy 10 litres
__________________
1/4 mile 15.6s non modified zs 180
see it here http://videos.streetfire.net/video/1...fadb5775a2.htm
piper cat back:
1/4 mile 15.0s 14/10/2006
see it here
http://videos.streetfire.net/video/d...6b0136725f.htm
xbox gamertag: callumsdaddy
johndjlawson is offline   Reply With Quote
Old 10-04-2006, 11:53   #170
roverman220
hi Simon. is it ok to pop in & see you as i'am down in redruth this week? just to get some advice
Old 10-04-2006, 11:54   #171
oilman
Registered User
oilman's Avatar
No problem at all roverman.
Just pop in and see us.
Simon.
__________________
Old 10-04-2006, 12:32   #172
roverman220
thanks mate, see you soon
Old 11-04-2006, 08:07   #173
MarkB
MarkB's Avatar
John DJ Lawson
I think you need (at least) about 5.2 litres on a ZS180.
Cheers Mark.
__________________
MarkB
MKII ZS220 Pilot
Old 11-04-2006, 20:21   #174
johndjlawson
Registered User
Quote:
Originally Posted by MarkB
John DJ Lawson
Cheers Mark.
cheers mark
i have ordered ten litres as opieoils have silkolene on offer at the moment
__________________
piper cat back:
see it here
Old 12-04-2006, 08:14   #175
MarkB
MarkB's Avatar
Don't be shy.... What is the special offer on at present? and the P&P ?
Mark.
__________________
MarkB
MKII ZS220 Pilot
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
