Oil Recommendations - Page 3 - XPowerForums - For MG, XPower & Motorsport Enthusiasts
Logo
Go Back   XPowerForums - For MG, XPower & Motorsport Enthusiasts > General Technical Section - ask the Experts! > Oil Recommendations - Fuel
Reply
Thread Tools
Old 06-12-2005, 00:22   #71
Screaming V6
Screaming V6 is on a distinguished road
Default Re: Oil Recommendations
Would Mobil 1 0-40 be ok to use in a standard ZT-T 160 (V6), the car does quite a few short trips as well as alot of high speed motorway driving.
Cheers Tom
Screaming V6 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-12-2005, 12:08   #72
gatvol
gatvol is on a distinguished road
In the classic Mini, the gearbox chews up the VI additives in no time on a cheap mineral so a 20W50 quickly gets to be a 20W40 or less. Go for a better oil with a good natural VI rather than an additive enhanced VI. But, do not use anything too slippery as the gearbox, needs a bit of friction for the synchro rings, and rolling element bearings will slide rather than roll. I have seen a very rapid failure of the idler gear bearing (crank to main input shaft) on an A series which also destroyed the housing around the bearing. What caused it was using an aftermarket additive to improve oil consumption on an older engine. The additive prevented the needles from rolling and they slid and wore flat spots which lead to the damage in short order. It also subsequently caused failure of the differential bearing when the brass cage was chemically attacked and collapsed allowing th eballs to escape and get chewed by the gearbox. It caused severe wear across the engine. SCRAP!
gatvol is offline   Reply With Quote
Old 06-12-2005, 12:13   #73
gatvol
Quote:
Cheers Tom
Tom
I have used Mobil1's 0W40 since the first service at 12k miles. Now on 76k miles on my V6 160 and no sign of oil consumption, usually good on fuel economy, less wear on start-up with better oil flow and less load on starter motor, too in the cold weather.
Ideal for short and long trips as the oil will be better able tocope with longer runs at higher speeds where engine temperature will be higher. But for short runs that cause the contamination build-up when the fuel/water/acids do not get burnt off, the oil will not be as easily damaged as cheaper oils.
If the car has a fair mileage on already (>60k miles) plan to do two changes within 500 miles as accumulated deposits from cheaper oils will be washed off the surfaces so could block filter/oilways. Not cheap doing it this way but better to be safer than sorry. If you plan to keep the car long term, do it, if not, stick with what you already use.
Old 07-12-2005, 15:26   #74
martinzt260
martinzt260 is on a distinguished road
What diff oil, gearbox oil and engine oil will I need for my ZT260? The car is not used daily, and covers about 5000 miles per annum on long runs.
martinzt260 is offline   Reply With Quote
Old 07-12-2005, 18:18   #75
Screaming V6
Cheers gavtol, Mobil 1 it is then
Cheers Tom
Old 08-12-2005, 10:36   #76
LM25
LM25 is on a distinguished road
Goose....
I suggest using a slightly thicker oil for your mini... as the same oil supplies both engine and gearbox.
Otherwise you may find youll have to change the oil every 1000 miles.
My mini has been running alot better since we done an oil change replacing with millers classic (non semi or synthetic).
its 15.76 for 5 litres.
http://www.millersoils.net/index2.html
LM25 is offline   Reply With Quote
Old 09-12-2005, 08:37   #77
MarkB
ZS220 - It's All About the Cams...
MarkB's Avatar
MarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to allMarkB is a name known to all
Hi Oilman,
Got a couple of questions for you regarding a ZS 180 Mk2, 20k miles:
1. What is the (OE recommended & your personal recommended) service intervals for gearbox oil ?
2. What grade do I need ? & how much ? [1.6 ltr rings a bell]
3. What brand(s) would you recommmend ?
4. How easy is it to change yourself with some spanners, a jack, some axle stands ? Or is it best left to the Pro's ?
Thanks for your help,
-Mark.
__________________
MarkB
MKII ZS220 Pilot
Voted Best Sports Saloon Gaydon 2006
183.9 BHP @ the Wheels (Measured)
221.6 BHP @ the Fly Wheel (Calculated)
Piper 270 High Lift Cams, Super Chips Custom re-Map
Janspeed Full Exhaust System & Open Filter Cone Custom set up
MarkB is offline   Reply With Quote
Old 15-12-2005, 08:35   #78
MarkB
MarkB's Avatar
Oilman,
Referring back to your recommendation to the Fire Engineer on 13/07/05:
"2003 2.5L V6 iTg induction, always runs super 97 RON with Booster 1.6 RON, road driving. Current oil Fully Synthetic Shell Helix unknown spec. "
I would recommend sticking with a fully synthetic.
0w-40 or 5w-40. API SL / ACEA A2 or A3
Simon"
I tried to find a 5w-40 full synth oil for my ZS180. I tried Halfords and 2 independent stockist - none of which had a 5w-40. They said that the 0w-40 would probably be too thin for my car and that it could burn a lot of oil as a result or even do damage. Is this true ?
There was a 5w-40 fully synth Halford own brand, but I didn't fancy that !
Will Mobil 1 0w-40 be okay for my car (ZS 180, Manifolds, panel filter, 20k miles) ?
Cheers Mark.
__________________
MarkB
MKII ZS220 Pilot
Old 15-12-2005, 09:09   #79
oilman
Registered User
oilman's Avatar
oilman is a jewel in the roughoilman is a jewel in the roughoilman is a jewel in the roughoilman is a jewel in the rough
Mark,
Yes, 0w-40 Mobil 1 or 0w-40 Castrol RS/Edge will be fine, or drop me a mail to [email protected] as I have plenty of 5w-40 true synthetics to choose from.
The Halfords own 5w-40 is a hydrocracked mineral oil and not a true synthetic.
Simon.
__________________
Use the code XPOWER and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: [email protected]
phone: 01209 202944 Engine Oil
oilman is offline   Reply With Quote
Old 15-12-2005, 15:54   #80
Wally_zr
Wally_zr is on a distinguished road
MG Re: Oil Recommendations
Hi Simon,
I have recently had a 2.0L turbo conversion to my 54 Mg105+
I have started using Shell Optimax Ron98 and have noticed big big power differences.
Can you recomend any specific oil?
Wally
Wally_zr is offline   Reply With Quote
Old 15-12-2005, 16:36   #81
MarkB
MarkB's Avatar
Thanks Oilman
Can you answer any of my questions above regarding gearbox oil ?
Cheers Mark.
__________________
MarkB
MKII ZS220 Pilot
Old 15-12-2005, 17:41   #82
oilman
Registered User
oilman's Avatar
Its MTF94 which I don't stock but I have a fully synthetic MTF by Amsoil that meets the specs.
Simon
__________________
Old 15-12-2005, 17:42   #83
oilman
Registered User
oilman's Avatar
Quote:
Originally Posted by Wally_zr
Hi Simon,
Wally
What will you be using the car for? Road/Track?
Simon
__________________
Old 16-12-2005, 15:31   #84
Paul Wiley
Paul Wiley is on a distinguished road
Due to the higher amount of VI improvers in 0W40 oils they to tend to initially thin. With longer OCIs, the oxidative thickening can counteract the thinning that intially occurs. M1 0W-40 may be designed this way on purpose so that at the end of a really long OCI, the viscosity is still in-grade, but due to the initial thinning may not always give the best results depending upon circumstances.
Paul Wiley is offline   Reply With Quote
Old 16-12-2005, 15:35   #85
oilman
Registered User
oilman's Avatar
5w-40 is generally a more shear stable grade than 0w-40 but it does depend on comparable basestock qualities though.
Simon
__________________
Old 16-12-2005, 16:31   #86
Paul Wiley
Redline race oils are probably the most shear stable available and the 40wt is listed as 15W40 and 10wt 0W10, so even their 5W40 road oil will use VIs and will be subject to shear.
In general Amsoil tends not to thin but does thicken, so perhaps M1 0W40 does use a thinner basestock than perhaps others on the market with a higher use of VIs.
Old 17-12-2005, 16:35   #87
zedster zs
Gone for a blast
zedster zs's Avatar
zedster zs will become famous soon enough
Oilman,
You recomended that i used a 5w 40w in my mg zs 180.Problem is i can only find 1 brand called millers that has that spec,is this oil any good.
If at all possible do you think we could have a price list put up.
zedster zs is offline   Reply With Quote
Old 17-12-2005, 22:20   #88
oe_cosgrove
oe_cosgrove is on a distinguished road
Quote:
Originally Posted by zedster zs
Oilman,
I have used Millers in a number of both serious power and 'daily drivers' for several years. I use 5w 40 fully synthetic racing spec. Hand on heart it is the best I have used. I will not under any circumstances use a '0W' oil.
oe_cosgrove is offline   Reply With Quote
Old 18-12-2005, 10:05   #89
Dave Morris
Registered User
Dave Morris's Avatar
Dave Morris is a jewel in the roughDave Morris is a jewel in the roughDave Morris is a jewel in the roughDave Morris is a jewel in the rough
Zedster.
I use Silkoline Pro S 5w-40 fuly synthetic in my 180. Simon supplied it next day delivery. It really quietened down my engine on cold start up.
__________________
Dave
Dave Morris is offline   Reply With Quote
Old 23-12-2005, 10:55   #90
Paul Wiley
0W oils I believe are used in Porsche Cup racing - 0W20 Titan GT1
http://www.fuchs.com.sg/faq.asp
Simon, do you have any inside info on this oil? (superb delivery even at this time of year) Any update on Millers analysis?
Old 04-01-2006, 16:02   #91
oilman
Registered User
oilman's Avatar
Paul, it's not available in the UK yet the only one we have here is the ester based Silkolene PRO R 0w-20 used in F1 cars and Superbikes.
http://www.opieoils.co.uk/TechSpecs/pror0w20.pdf
Due to Christmas break, no news on the Millers yet.
Hows the PRO S?
Simon
__________________
Old 05-01-2006, 13:10   #92
Dave Turbo
Dave Turbo is on a distinguished road
I use Mobil 1 5W 40. Can't find it in the UK though. May go to the Pro S after my Mobils run out.
Dave Turbo is offline   Reply With Quote
Old 05-01-2006, 13:28   #93
oilman
Registered User
oilman's Avatar
Would recommend that you look at several quality ones on our website (shop will be up in the next week too).
Fuchs Titan Supersyn SL 5w-40
Silkolene PRO S 5w-40
Motul 8100 5w-40
Motul 300V 5w-40
To name a few that we have.
Simon
__________________
Old 07-01-2006, 16:05   #94
Gas-Axe
Gas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant futureGas-Axe has a brilliant future
Quote:
I bet that's a pretty price, too!!
Gas-Axe is offline   Reply With Quote
Old 07-01-2006, 16:57   #95
oilman
Registered User
oilman's Avatar
You'll find it for sale in my online shop from late sunday or monday AM and yes it is expensive. http://www.opieoils.co.uk
Simon
__________________
Old 10-01-2006, 20:41   #96
andylew0
Tick Tock Tick Tock
andylew0's Avatar
andylew0 is infamous around these partsandylew0 is infamous around these parts
wot oil for 120 zr 53 plate cheers andy
andylew0 is offline   Reply With Quote
Old 11-01-2006, 10:29   #97
oilman
Registered User
oilman's Avatar
Quote:
Cost option = 10w-40 semi synthetic changed every 5-6,000 miles.
Quality option = 5w-40 Full synthetic changed evert 10,000 miles.
Plenty to have a look at on my new site.
Simon.
__________________
Old 12-01-2006, 23:00   #98
Paul Wiley
Simon,
Do you test filters as well. View on best worst on market?
Paul
Old 12-01-2006, 23:04   #99
oilman
Registered User
oilman's Avatar
Quote:
Originally Posted by Paul Wiley
Simon,
Paul
Paul,
We have not conducted a test on filters, my advice is always go for a reputable brand.
We supply Purolator and they come well recomend, a good price too.
Have a look on my site at the online reference for which one you need for you car.
Guy.
__________________
Old 13-01-2006, 17:18   #100
wirly
wait and see;-)
wirly's Avatar
wirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to beholdwirly is a splendid one to behold
Simon what are your thoughts on Millers oils
noticed they in the paddock at donnington at track days so they must be used at the track
but will these be different to what is sold to public
cheers
Paul
__________________
Team ZS
wirly is offline   Reply With Quote
Old 13-01-2006, 17:36   #101
oilman
Registered User
oilman's Avatar
Supposed to be good, we dont know for sure so we are having some chemically tested, so I hope it is as good as they say.
In theory, other than extreme applications it should be the same oil available to the general public.
Simon.
__________________
Old 13-01-2006, 19:22   #102
oe_cosgrove
cheers
Paul
It is the same oil. Millers is a small company producing what I have found to be the best so far.
I keep posting about Millers and thought I should tell you I dont sell it and have no financial interest in the product or company!
Paul
Old 15-01-2006, 18:37   #103
Gas-Axe
OEM filters everytime for me. No contest.
I know they might well be rebadged Fram etc but it's a policy I've always had!
Old 15-01-2006, 19:39   #104
Aidan
Registered User
Aidan is on a distinguished road
Hi
What oil would you recomend for engine longevity (not just cost);
-2004 TF160 with X power exhaust and itg panel filter. 10,000 a year road use.
-2002 ZS120 with X power exhaust and itg panel filter, 10,000 a year road use?
Also is it worth changing the oil every 5,000 miles instead?
Thanks,
Aidan
Aidan is offline   Reply With Quote
Old 15-01-2006, 20:57   #105
oe_cosgrove
Quote:
Originally Posted by Aidan
Hi
Thanks,
Aidan
Millers..........check in your handbook for viscosity. Their 'Fully Synthetic Racing Specification' the best. Despite lower cost it is IMHO the best.
Paul
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
